- 14 Ago 2018 às 14:33
#35767
BOA TARDE ESTOU TENTANDO CRIAR UMA PLANILHA DE VENDAS QUE BAIXA O ESTOQUE ENCONTREI ESSA MACRO NA NET, FIZ ALGUMAS ALTERAÇOES MAS NAO CHEGUEI AO RESULTADO QUE EU QUERIA, SEGUE A MACRO:
Sub copiar()
Range("C14:C214").Select
Selection.Copy
Sheets("SAÍDA").Select
Range("A3").Select
Do
If ActiveCell <> "" Then
Loop Until ActiveCell = ""
ActiveCell.PasteSpecial Paste:=xlPasteAll, Operation:=xlNone, SkipBlanks:= _
False, Transpose:=False
Essa macro tem a seguinte função
A macro Copia (C14:C214) plan01
A macro cola na plan SAIDA (A2:A214)
A macro cola (A215:A300) plan02
Sempre na sequencia da primeria celula vazia.
Eu precisava que ela copiasse (B14:B214)Planvenda, colasse (A3:A214)PLAN SAIDA
copiasse (C14:C214) Planvenda, colasse (B3:B214)PLAN SAIDA
(H14:H216)Planvenda, colasse na (C3:C200) PLAN SAIDA
copiasse (I16:I216)Planvenda e colasse (D2:D200) na PLAN SAÍDA
Sub copiar()
Selection.Copy
Range("A3").Select
Do
