Hi, @ygrace680!
Did you tried to use document.GetElementById() or document.QuerySelector() with VBA?
  • GetElementById() to catch values from DOM by the items IDs;
  • QuerySelector() to catch values from DOM by items type like class, id, methods (i.e. <span>, <div>, <h1>, <p>, etc.);
You can inspect through pages codes by pressing right click and going in "Inspect Element", for example.
I've seen the page and is more easy using QuerySelector().. anyway.. it's an option! Try this if you want.
Good luck!
Huggies
