- 17 Jul 2018 às 01:38
#34875
Hello,
I have download the trial version of "PockerTracker". But i cant start it, have problems with PostgreSQL. After the installation i run "PockerTracker", it start and wont connect to SQL. I let the default settings in the connection box. But trying to connect i get the info: unable to connect to this database. please check the configuration. I read the guides in the forum also other topics. I check if PostgreSQL is running and find it at the services: postgresql-8.4 - PostgreSQL Server 8.4 is running logged as: .\postgres Maybe the login is failed?
Infos: I have win7 and i installed also HoldemManager in the trial version, maybe have troubles with holdemmanager??
Any help will be apprecited.
I didn't find the right solution from the Internet.
References:
https://www.pokertracker.com/forums/vie ... hp?t=37678
Product Video Service
Thank you.
References:
Thank you.
