- 17 Out 2020 às 09:08
#59756
bom dia ,
estou tentando desenvolver um programa de vendas no excel ,sendo que o meu código para remover o botão x do formulario so funciona na versão 32 bits
gostaria de converte esse codigo para 64 bits
Private Declare Function FindWindow Lib "user32" Alias "FindWindowA" (ByVal lpClassName As String, ByVal lpWindowName As String) As Long
Private Declare Function GetWindowLong Lib "user32" Alias "GetWindowLongA" (ByVal hWnd As Long, ByVal nIndex As Long) As Long
Private Declare Function SetWindowLong Lib "user32" Alias "SetWindowLongA" (ByVal hWnd As Long, ByVal nIndex As Long, ByVal dwNewLong As Long) As Long
Private Declare Function DrawMenuBar Lib "user32" (ByVal hWnd As Long) As Long
Sub removeCaption(objForm As Object)
Dim lStyle As Long
Dim hMenu As Long
Dim mhWndForm As Long
If Val(Application.Version) < 9 Then
mhWndForm = FindWindow("ThunderXFrame", objForm.Caption) 'XL97
mhWndForm = FindWindow("ThunderDFrame", objForm.Caption) 'XL2000+
lStyle = GetWindowLong(mhWndForm, -16)
lStyle = lStyle And Not &HC00000
SetWindowLong mhWndForm, -16, lStyle
DrawMenuBar mhWndForm
Dim lStyle As Long
Dim hMenu As Long
