Como salvar .pdf com valor da célula personalizada "00045"
A célula O2 está personalizada em "00000", mas salva o arquivo "45.pdf" ao invés de "000045.pdf"
OBS: o valor de "O2" nunca será o mesmo.
Grato pela ajuda
Sub PDF2()
Dim sh As Worksheet
Dim TempFilePath As String
Dim TempFileName As String
Dim FileName As String
Dim vCelula As Range
For Each vCelula In Range("O2").Cells
vCelula.Value = vCelula.Value + 1
ActiveWorkbook.Save
TempFilePath = "D:\PDF\"
'Loop through every worksheet
For Each sh In ThisWorkbook.Worksheets
FileName = ""
'Test A1 for a mail address
If sh.Range("M8").Value Like "?*@?*.?*" Then
'If there is a mail address in A1 create the file name and the PDF
TempFileName = TempFilePath _
& "CVLO" _
& " " _
& Sheets("A").Range("M3").Value _
& " " _
& Sheets("A").Range("O2").Value _
& Format(Now, " dd-mm-yyyy h-mm") _
& ".pdf"
FileName = RDB_Create_PDF(Source:=sh, _
FixedFilePathName:=TempFileName, _
OverwriteIfFileExist:=True, _
OpenPDFAfterPublish:=False)
Next sh
