- 02 Jan 2020 às 15:50
#51425
Sub INSERIR()
If Range("A4").Value <> "" Then
Range("A4:K4").Select
Selection.Copy
Range("A7").Select
If Range("A8").Value <> "" Then
Selection.End(xlDown).Select
:=False, Transpose:=False
If Range("A8").Text = "S" Then
Range("F8").Value = Range("F8").Value * -1 ESTA FUNÇÃO NÃO MOSTRA VALOR APENAS COPIA E COLA
Selection.ClearContents
Range("A4").Select
Selection.Copy
Range("A7").Select
Range("A4").Select
