Encontrei o código abaixo (
neste link), pode ser uma luz para o que deseja.
O que ele faz:
1. Abre o IE
2. Navega até o site google.com
3. Maximiza o IE
4. Tira o screeshot (print screen)
5. Executa o MsPaint
6. Cola o ScreenShot no MsPaint
Código: Selecionar todosPrivate Declare Sub keybd_event Lib "user32" (ByVal bVk As Byte, ByVal bScan As Byte, _
ByVal dwFlags As Long, ByVal dwExtraInfo As Long)
Private Declare Sub Sleep Lib "kernel32.dll" (ByVal dwMilliseconds As Long)
Private Const VK_SNAPSHOT As Byte = 44
Private Declare Function FindWindow Lib "user32" Alias "FindWindowA" (ByVal _
lpClassName As String, ByVal lpWindowName As String) As Long
Private Declare Function ShowWindow Lib "user32" (ByVal hwnd As Long, ByVal _
nCmdShow As Long) As Long
Private Const SW_SHOWMAXIMIZED = 3
Private Const VK_LCONTROL As Long = &HA2
Private Const VK_V = &H56
Private Const KEYEVENTF_KEYUP = &H2
Sub Sample()
Dim IE As Object
Dim hwnd As Long, IECaption As String
Set IE = CreateObject("InternetExplorer.Application")
IE.Visible = True
IE.Navigate "www.Google.com"
Sleep 5000
'~~> Get the caption of IE
IECaption = "Google - Windows Internet Explorer"
'~~> Get handle of IE
hwnd = FindWindow(vbNullString, IECaption)
If hwnd = 0 Then
MsgBox "IE Window Not found!"
Exit Sub
'~~> Maximize IE
ShowWindow hwnd, SW_SHOWMAXIMIZED
DoEvents
'~~> Take a snapshot
Call keybd_event(VK_SNAPSHOT, 0, 0, 0)
'~~> Start Paint
Shell "C:\Windows\System32\mspaint.exe", vbNormalFocus
Sleep 3000
'~~> Paste snapshot in paint
keybd_event VK_LCONTROL, 0, 0, 0
keybd_event VK_V, 0, 0, 0
keybd_event VK_V, 0, KEYEVENTF_KEYUP, 0
keybd_event VK_LCONTROL, 0, KEYEVENTF_KEYUP, 0
